1980 kz650ltd bonehead move. Now
  • rebreath
  • rebreath's Avatar Topic Author
12 Mar 2021 13:04
#844827
I need more guidance from you folks. So, bought a new battery and after much discussion got(what I thought) correct battery. Even had old one with me! Finally got to filling and charging. Went to plug in, big sparks(major clue to those dumber than me) plugged anyway, turned key blew 20amp that feeds my dyna ignition. Now with old, but correct(has enough charge for testing purposes) battery connected, turn key, fuse pops. Did I cook my dyna?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1980 kz650ltd bonehead move. Now
12 Mar 2021 14:52
#844831
Looks like you have a massive shortcut some where in your wiring harness!!!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Mar 2021 14:52
#844832
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Mar 2021 14:53
#844833
  • rebreath
12 Mar 2021 15:26
#844834
I REALLY want to know what you guys think. Alas though I am getting this message
"Rendering Error in layout Message/Item: Call to undefined method KunenaUser::getname(). Please enable debug mode for more information."
and thus am unable to see anything but that message. Please feel free to contact me directly at [email protected] as I have no idea how to fix whats going on with the site
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Mar 2021 15:42
#844837
rebreath wrote: I REALLY want to know what you guys think. Alas though I am getting this message
You/we all have to wait until the site error is fix by the Admins/Mods. So be patient and stay tuned like me and the other members here...
  • F64
  • F64's Avatar
  • 81-KZ440D2
12 Mar 2021 22:00 - 12 Mar 2021 22:03
#844842
go grab a bunch of 20 amp fuses.
disconnect the dyna.
put in a 20 amp fuse
turn on the bike
if the fuse pops it's something else
if the fuse doesn't pop, plug in the dyna
if it pops, it's the dyna
It could be your regulator/rectifier.
Those things don't like reversed battery leads.
Unplug that if the fuse pops without the dyna connected
then put in another fuse
81-KZ440-D2.
LIC, NY
Last edit: 12 Mar 2021 22:03 by F64.
13 Mar 2021 05:52
#844850
Are you sure you hooked the wires up correctly to the battery? In other words the positive wire to the positive terminal and the negative wire to the negative terminal? Ed
  • F64
  • F64's Avatar
  • 81-KZ440D2
13 Mar 2021 07:37
#844857
Ed,
Rebreath doesn't quite come out and say it.
But they probably bought a battery that has the positive and negative terminals flipped. Without verifying the two batteries were the same, hooked it up and boom.
81-KZ440-D2.
LIC, NY
