Help on my KZ750 cylinders 1-4 aren’t firing.
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
20 Feb 2021 18:29
#843801
So on my way home tonight I was driving everything seemed fine. No problems. After about 30 minutes of on the interstate my bike all of sudden my bikes cylinder 1-4 cut out and stopped running. I was able to get her started and on two cylinders and get home. But I don’t know why one coil would have no power and the other would. Is my coil bad? Could a lose connection cause one coil to stop working? Any help would be appreciated. I’ve had some charging issues in the past idk if they’re related or not. And I feel like I remember this happening before but last time power was cut to the entire bike from what I remember. Same thing happened but it happened like a year ago and I haven’t had any problems since. I’ll fiddle wi the the wires another day and see what I can find.
Thanks!
  • hardrockminer
  • hardrockminer's Avatar
Re: Help on my KZ750 cylinders 1-4 aren’t firing.
20 Feb 2021 19:38
#843804
Check and clean all your connections. If that doesn't solve your problem then try switching the coils around. (You will need to rewire them accordingly.) If 1 and 4 work with the coil from 2 & 3 then the problem is likely the coil. You can check it by measuring resistance on the primary (sparkplug wire to sparkplug wire) and secondary sides. You should get 2 to 4 ohms on the primary and 15k ohms on the secondary, or perhaps higher. If the resistance checks out then the coil is OK and your problem is either in the pickup or in the exciter, if you have one. (I'm assuming you don't have points.)
  • JohnLuke
20 Feb 2021 19:43
#843805
Okay. Will do. I’ll try to that sometime this week if I can. It’s got a dyna s ignition system I installed way back when I built it.
  • hardrockminer
21 Feb 2021 05:01
#843811
Do the pickups wire directly to the coils or do they wire to an exciter and then the exciter goes to the coils?
  • JohnLuke
21 Feb 2021 05:05 - 21 Feb 2021 05:06
#843812
Straight to the pickups. It’s a very simple system. Power goes to the coils and then you have the wires from the pickups. That’s it.
Last edit: 21 Feb 2021 05:06 by JohnLuke.
  • martin_csr
  • martin_csr's Avatar
21 Feb 2021 08:17 - 21 Feb 2021 08:25
#843818
The first thing I'd do is redo all of the spark plug wire connections. The plug wires unscrew from the coils by unscrewing the ribbed compression boots. Untwist the spark plug caps from the plug wires. Nip off the ends of the wires a tad to freshen up the connections, especially if they have the greyish oxidation. I solved an intermittent firing problem by doing this (but later on replaced the coils w the green Dynas & installed a Dyna spark plug wire set).
Next, if that doesn't solve the problem, I'd swap the ignition coils to see if the problem follows the coils
You could also use a meter to test stuff. An ignition coil can test fine cold but fail under load when the engine is running.
I think some guys heat them with a heat gun to mimic running conditions.
Last edit: 21 Feb 2021 08:25 by martin_csr.
  • Mikaw
  • Mikaw's Avatar
21 Feb 2021 08:28 - 21 Feb 2021 08:32
#843819
I agree with all the above. I’d start with the least destructive test first. Pull all the plugs put the back into the plug wires and lay them on the engine case. Make sure they have good contact. Crank the bike over and look for spark. This is better done in a dark garage or at night. You need a meter and test voltage at the coil primary. Just remember when testing individual coils the both secondary’s need to be grounded for an accurate test. The last page has some trouble shooting.
Last edit: 21 Feb 2021 08:32 by Mikaw.
  • hardrockminer
21 Feb 2021 10:23
#843829
So no exciter. That means the coils should be 3.8 to 4.2 ohms on the primary side.
If two cylinders won't fire, it means the likely cause is either the coil or the pickup or the wiring.
1) Check the wiring for any unplugged wires. Clean all the contacts. Still no spark?
2) Check the coil for correct primary and secondary resistance. A short in the coil means it must be replaced. Coil is OK?
3) Your pickup is probably shot. Replace it.
  • Nessism
  • Nessism's Avatar
21 Feb 2021 10:56
#843830
First thing I'd do is check the battery to make sure it's properly charged.
The following user(s) said Thank You: martin_csr
  • hardrockminer
21 Feb 2021 12:17 - 21 Feb 2021 12:17
#843832
What I'm about to describe isn't the source of your problem but I've had trouble with this in the past. Look at P2 of the information Mikaw posted. At the bottom you will see how the power for the pickup is transferred through a hot connection on the bike via a push clip. That push clip often makes a bad connection, which interrupts power to the pickup. I have Dyna on all my bikes and I attach that red wire from the pickup directly to a hot connection on the bike. On the 900's/1000's there is a spare brown wire near the headstock that will provide necessary power. I'm guessing (but I don't know) there is a spare hot wire on your bike as well.
Last edit: 21 Feb 2021 12:17 by hardrockminer.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
21 Feb 2021 13:03
#843833
The same thing happened to me. One of the wires going to the coil for 1&4 had just come off. Hopefully your solution is as simple...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • krazee1
  • krazee1's Avatar
21 Feb 2021 14:19
#843836
I have experienced on more than a couple occasions coils that work when cold, and then fail when hot.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
