Motobatt battery
- ThatGPzGuy
Motobatt battery
07 Feb 2021 13:03
Just a shout out to Motobatt. I was working on the GPz today and wondered how old the battery was. Checked my maintenance notes and turns out I bought it in August 2013 so still going strong after 7 1/2 years.
Every other bike I own has gone thru two or more batteries in the same time frame. Not bad at all...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: JR
- JR
Re: Motobatt battery
07 Feb 2021 15:00 - 07 Feb 2021 15:02
Thank You
That seals it. I'm gonna order a Motobatt in the next few weeks. The last 3 years I've had 2 lead acid batteries from Canadian Tire (made in Vietnam) each of which lasted about 50 weeks and the most recent one was Yuasa which I installed in June 2020 and removed at Halloween when I put the bike away for Winter. About 10 days later I put the Yuasa on charger and the best it went was 12.5V fully charged. Well on its way out.
There was a time when a lead acid battery would last 5 years. Sad to say that quality has declined
Last edit: 07 Feb 2021 15:02 by JR.
- cb900f
07 Feb 2021 17:02
I've never got more than 2 riding season out of a regular led acid wet cell. I only buy AGM batteries (Deka Big Crank is my battery of choice) which I can usually get at least 7 years out of.
- Polish
07 Feb 2021 17:14
Are the AGM and Motobatt lead acid? Do you need to upgrade the regulator/rectifier?
Thx
JL
Thx
JL
1979 Honda CB400T Cafe Racer (current ride)
1982 KZ750 LTD (current project)
07 Feb 2021 17:23 - 07 Feb 2021 17:24Polish wrote: Are the AGM and Motobatt lead acid? Do you need to upgrade the regulator/rectifier?
Thx
JL
Absorbant Glass Mat (AGM) battery. Basically lead acid but the acid is absorbed and the case is sealed. Charge voltage is 14.5 VDC. Get a SH775 Series type R/R if you want to optimize your charging system.
batteryuniversity.com/learn/article/absorbent_glass_mat_agm
Last edit: 07 Feb 2021 17:24 by Nessism.
- davido
09 Feb 2021 11:04
I fitted a Motobatt in my Z. It lasted a couple of months,I think, then died as I was trying to start the bike. When I went to pull it out it was VERY warm. Almost hot! That got me worried so I replaced it with a Yuasa. No problems since.
Saying that,Ive also had a Motobatt in my 600 Bandit for years. Never had a problem with it and its still going strong.
Thats my tuppence worth.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Irish Yobbo
15 Feb 2021 15:41davido wrote: I fitted a Motobatt in my Z. It lasted a couple of months,I think, then died as I was trying to start the bike. When I went to pull it out it was VERY warm. Almost hot! That got me worried so I replaced it with a Yuasa. No problems since..
If a battery is getting hot, it's often a problem with the charging system. Have you checked your voltage at higher revs and with the headlight on to make sure it's not overcharging?
In my experience, lower voltage (~14V) tends to keep the battery in better condition long term. I got around 13 years and over 350,000km from an AC Delco battery in a daewoo - it used to charge at bang-on 14V.
1981 KZ750 LTD
