Converting points and regulator
- Ha5611
31 Jan 2021 10:34
Hi guys
I own a 76 kz650B1 running standard points ignition and a separate regulator and rectifier
My question is can I fit the pickup coils and igniter box off a kz550
And can I convert my regulator and rectifier to the combined unit off of a kz550 also
Many thanks
Many thanks
Re: Converting points and regulator
31 Jan 2021 14:35 - 31 Jan 2021 14:35
Correction - you own a 1977 KZ650-B1 that may have been built in 1976. Ed
Last edit: 31 Jan 2021 14:35 by 650ed.
01 Feb 2021 09:56
The '77 650 used a field coil stator right? Can't use a regular R/R for that application.
