KZ 750 Twin - 1983, Wiring Diagram Europe
- Hedlo
01 Jan 2021 15:36
Looking for a Wiring Diagram (Europe version) for my KZ 750 Twin - 1983.
Can only find a European version of the 1976 model in the Fielbase. Not sure if that drawing works for my model.
Appriciate your advice.
Re: KZ 750 Twin - 1983, Wiring Diagram Europe
01 Jan 2021 19:55 - 01 Jan 2021 20:04
Howdy. Here's a topic with a Z750-S1 (Euro model) wiring diagram. It's black-&-white and kind of hard to read, though.
Scroll down to reply #778370 by the op kzswe & click the attachment.
kzrider.com/forum/4-electrical/607803-which-wiring-diagram
Last edit: 01 Jan 2021 20:04 by martin_csr.
The following user(s) said Thank You: Hedlo
02 Jan 2021 07:13 - 02 Jan 2021 07:57
Just an FYI. There's a 79-84 KZ750 Twin factory service manual on EB right now that covers various Euro models, including the 750-S1/S2/Y1/Y2 Twin motorcycles. I don't know if this is a complete manual, but it probably has the wiring diagrams for the models listed on the back cover. It doesn't say supplement on it, so I would assume it's a stand alone manual. At any rate it should have the specs for the models listed.
Last edit: 02 Jan 2021 07:57 by martin_csr.
- gd4now
- Denco where did you go?
02 Jan 2021 09:46
You can find manuals and wiring diag at this location
kz750twins.com/?p=15
The 83 supplement here jpavlov.files.wordpress.com/2008/12/kawkz750twinsup83.pdf
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- loudhvx
02 Jan 2021 14:34 - 02 Jan 2021 14:34
The charging system, and probably the ignition would be totally different between a 1976 and 1983 Kz750 twin, regardless of continent.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 02 Jan 2021 14:34 by loudhvx.
- Hedlo
03 Jan 2021 02:18
Thanks for charing.
I will give it a try. If I fail I will have to go with a M Unit.
