Yuasa battery
- gordone
Re: Yuasa battery
26 Nov 2020 13:46
I was thinking about the first time I charge it after I have filled it with acid, if I needed a special charger the first time.
After some googling the conclusion is NO
Project:
Project:
- seanbarney41
- '79 kz1000 LTD '75 Honda CB750
Re: Yuasa battery
26 Nov 2020 18:34
You have to be careful with kz650's. I see a lot of sellers listing a battery that is just slightly too tall. It will work perfectly but your seat will contact + and - on the bigger bumps which, of course, makes for badness. The situation can be remedied with some heavy rubber covers over the battery posts. It seems like the correct size battery is not available from many manufacturers, so they have substituted the nearest size that "almost" works,
- gordone
Re: Yuasa battery
26 Nov 2020 23:13 - 26 Nov 2020 23:13seanbarney41 wrote: You have to be careful with kz650's. I see a lot of sellers listing a battery that is just slightly too tall. It will work perfectly but your seat will contact + and - on the bigger bumps which, of course, makes for badness. The situation can be remedied with some heavy rubber covers over the battery posts. It seems like the correct size battery is not available from many manufacturers, so they have substituted the nearest size that "almost" works,
Thank you, the mesaurments seller have listed on ebay is lower then the cheap battery I have now, so I think it shall be good.
www.ebay.com/vod/FetchOrderDetails?sspag...ransid=2185752530008
Project:
Project:
Last edit: 26 Nov 2020 23:13 by gordone.
- gordone
Re: Yuasa battery
27 Nov 2020 02:42
Project:
Project:
