LTD440 - Neutral light doesn't turn on
- Jasper.R
19 Nov 2020 07:36
Hi,
The Neutral light doesn't work on my LTD440 (1983). It didn't work when I bought it, so I have no idea where to start looking. Any advice?
- gd4now
- Denco where did you go?
Re: LTD440 - Neutral light doesn't turn on
19 Nov 2020 09:20
I do not have a wiring diagram for that year and model, but do for several earlier ones. It appears to be a simple circuit in that power comes from the keyed switch to the light and then a wire goes to the neutral switch which provides ground. The circuit is closed only when the trans is in neutral, all connections are tight and the bulb is functioning.
I would check that the neutral switch is screwed in tight, the light bulb itself is not burned out, and all the wires and connections between the keyed switch and the light bulb and neutral switch have good connections.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
20 Nov 2020 06:49 - 20 Nov 2020 06:53
I would make sure the bulb is good first. The neutral switch is going to be behind the LH engine sprocket cover,
near the front sprocket (or pulley if it's a belt drive). It usually has a light green wire. If it's chain drive, the
switch can get pretty grungy. Mine was glitchy, so I pulled off the flag terminal & cleaned up everything.
The terminal didn't fit tight, so I crimped it a tad, then installed it onto the switch.
Last edit: 20 Nov 2020 06:53 by martin_csr.
- F64
- 81-KZ440D2
20 Nov 2020 21:01
do you have a voltmeter?
81-KZ440-D2.
LIC, NY
LIC, NY
- Jasper.R
23 Nov 2020 02:56
Thanks a lot guys!! Fixed. The cable had come loose, which revealed itself after I took off the left-hand engine cover. Sadly it has already come loose after driving back home for 30km, so I'll put on a hose clamp next time I have time. That should keep it in place.
The bulb was fine!
The bulb was fine!
23 Nov 2020 05:20 - 23 Nov 2020 05:21
Thanks for the report. Do you mean the wire terminal came off the neutral switch?
Last edit: 23 Nov 2020 05:21 by martin_csr.
- Jasper.R
23 Nov 2020 08:06
Yes correct; the green wire/plug came loose off of the switch.
23 Nov 2020 08:43 - 23 Nov 2020 15:23
I would carefully re-crimp the terminal. You shouldn't need to add a clamp. I have a good crimper that was a good fit. I'm assuming your bike has the same flag-type terminal. see pic. I don't know exactly what type of terminal it is, so I call it a flag terminal. scirocco chimed in one time but I forget. doh.
ps: I guess it's possible the terminal post on the neutral switch is messed up, in which case I suppose you could need a clamp. ???
Last edit: 23 Nov 2020 15:23 by martin_csr.
- Jasper.R
24 Nov 2020 04:40martin_csr wrote: I would carefully re-crimp the terminal. You shouldn't need to add a clamp. I have a good crimper that was a good fit. I'm assuming your bike has the same flag-type terminal. see pic. I don't know exactly what type of terminal it is, so I call it a flag terminal. scirocco chimed in one time but I forget. doh.
I was wrong, the cable is still connected and working fine. Think I might have turned off the contact too fast or left it in first gear, it's all working flawless still! My bad.
