Odometer broken glass
- Daanio
31 Oct 2020 04:18
undefined Hi all, on my new kz1000j bike the glass in the odometer is broken. That odometer seems sealed or glued. On fb someone suggested to disc it open with a Dremel which im alsof thinking about. Probleem seems i cannot reach all the seams with the Dremel. Any tips?
Attachment not found
Re: Odometer broken glass
31 Oct 2020 06:17
NNNNNNOOOOOOOO!!!!!!!!
PUT THE DREMMEL AWAY!!!
www.kzrider.com/articles/technical-tips/39-gauge-glass-clean-up
- Daanio
31 Oct 2020 06:29 - 31 Oct 2020 06:31
Problem is that he is talking about the gauges.. mine is only the odometer. Im having troubles uploading pics.. its saying no permission.
Attachment IMG_20201031_093704.jpg not found
Attachment IMG_20201031_093715.jpg not found
Attachment IMG_20201031_122420.jpg not found
Last edit: 31 Oct 2020 06:31 by Daanio.
The following user(s) said Thank You: martin_csr
31 Oct 2020 07:10 - 31 Oct 2020 07:28
Most KZ meters aren't meant to be disassembled & you may be going into uncharted territory in this case. Only suggestion I have is to start prying from the back side to see if you can pop it open. The best analogy I can think of is a TV remote control that doesn't work >> you can pry them apart but doing so causes some damage to the shell (I used a painters 6-in-1 tool).
ps: a 1000J is kind of a desirable model, so I'd consider getting a junk one off of EB for practice. I saw one that was pretty cheap, comparatively speaking, but its glass was also broken. assuming you can't find a good replacement.
Last edit: 31 Oct 2020 07:28 by martin_csr.
- Daanio
31 Oct 2020 09:47
Yup well i got the easy side loose but that is only one out of 4 sides. I did use the Dremel. Problem is I cant get the other sides because there is a lip and some more problems. Im sure that when aI pry it I will break the plastic. Tried heating it but it makes the plastic weak.
- daveo
31 Oct 2020 11:24
Ebay shows a dozen currently available: kz1100 odometer
Replaced twice since I found her twenty years ago.
1982 KZ1100-A2/1170 sleeper 😀
- Daanio
01 Nov 2020 01:19
Yup but they are mph and i need kph. got it open though but was hard. Even the glass plate holder is sealed! Doubt I will get it cleanly assembled but you never know..
Attachment IMG_20201101_094926.jpg not found
Attachment IMG_20201101_101050.jpg not found
01 Nov 2020 06:20
Thanks & thanks for the pics. This may help someone in the future.
01 Nov 2020 06:28I am sorry, my mistake. Still, I would use a dremmel only as a very last resort. What adhesive are you planning to use to seal it back up?Daanio wrote: Problem is that he is talking about the gauges.. mine is only the odometer. Im having troubles uploading pics.
- daveo
01 Nov 2020 06:29 - 01 Nov 2020 07:29
Oops...metric, aha! :S
I disassembled one of these, and kept it around for a spare until it landed in a dumpster three years ago. I used an Xacto knife to cut, and pried in several places along the seam with something else, and somehow avoided mangling the case in the process. It would have been ideal case to transfer internal workings, and reassemble with two-part epoxy.
Last edit: 01 Nov 2020 07:29 by daveo.
- Daanio
01 Nov 2020 22:50
I got it fixed. I cut out a small piece of glass, assembled with the rubbers but without that glass plate holder and siliconed it. I sealed it with high tack silicone. Didn't have 2k glue laying around . Its not moving so Im good. Can use different glue if it comes loose but doubt it.
Attachment IMG_20201101_140422.jpg not found
Attachment IMG_20201101_164442.jpg not found
Attachment IMG_20201101_173008.jpg not found
- daveo
17 Nov 2020 15:46 - 17 Nov 2020 16:15
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationAvailable as of this post:
Last edit: 17 Nov 2020 16:15 by daveo.
