Oil filled starter motor?
  • KZNinja
  • KZNinja's Avatar Topic Author
29 Oct 2020 03:02
#837918
1979 KZ650 D2 SR
I have zero experience with motorcycle starters, have had a car starter / lawn mower starter opened up once or twice and never seen oil in those, and have cleaned up cordless drill commutators / brushes in the past. Guessing it is not supposed to be filled with oil, and the oil got past the seal as the seal has a couple folded over spots from what looks like perhaps installing it dry.
Took it out to inspect / clean up the brushes and commutator, but it leaked a ton of oil all over, had to be a quarter of the way filled with oil.
I need to sand (or should I say emery cloth) the commutator as it looks pretty rough, and one of the brushes is shot, but I might be able to shim it for testing purposes. Bearings feel fine and spins by hand okay.
I got the motor to spin slowly if I rotated it while connected to a battery, but if not in the right sot it was just dead. The rest of the starter system seems to be working okay.
Attachment IMG_0580.JPG not found
Attachment IMG_0584.JPG not found
Attachment IMG_0586.JPG not found
1979 KZ650 D2 SR
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Oil filled starter motor?
29 Oct 2020 03:20 - 29 Oct 2020 03:30
#837920
The inside of the starter motor should be dry, only a little dust from the brushes. The commutator need only a very light sanding to clean up and even the surface. Your rotor shaft seal looks damaged and let the engine oil flow into the starter body.
Attachment IMG_0584-1.jpg not found
Last edit: 29 Oct 2020 03:30 by Scirocco.
The following user(s) said Thank You: KZNinja
  • KZNinja
29 Oct 2020 03:36 - 29 Oct 2020 03:38
#837921
Scirocco wrote: The inside of the starter motor should be dry, only a little dust from the brushes. The commutator need only a very light sanding to clean up and even the surface. Your rotor shaft seal looks damaged and let the engine oil flow into the starter body.
Okay, that’s what I thought then, I seen the damaged area's of the seal (two damaged spots) and know that is always a bad thing. Just wanted to make sure as I have zero experience with motorcycles like this, and wanted to be sure it wasn't some weird design I am unfamiliar with.
Thank you!
1979 KZ650 D2 SR
Last edit: 29 Oct 2020 03:38 by KZNinja.
  • zed1015
  • zed1015's Avatar
29 Oct 2020 04:39
#837923
If there's no other damage then it just needs the oil washing out, fit a new seal, square the commutator segments on a lathe, cut back the mica between them with a small hacksaw blade , fit new brushes and you should be good to go.
  • TexasKZ
  • TexasKZ's Avatar
29 Oct 2020 07:21
#837934
If you want to see a deep dive into a KZ650 starter, take a look at this thread. You will need to scroll down pretty far on the first page to pick up the beginning of the starter refresh.
www.kzrider.com/forum/11-projects/610746...cafe-racer?start=252
