1979 kz twin wire-up.
  • the droom
  • the droom's Avatar Topic Author
28 Oct 2020 15:25
#837903
undefined greetings new member here,
i have a 1979 kz 750 twin..... i want to re-wire this engine for use in another custom shop built frame......
my problem is ....... how do i wire this engine up ?
  • BobberDan
  • BobberDan's Avatar
Re: 1979 kz twin wire-up.
05 Nov 2020 20:21
#838154
Single hot wire to the coil and a real good battery...Are you kicking or push button starting
  • martin_csr
  • martin_csr's Avatar
06 Nov 2020 06:03 - 06 Nov 2020 06:12
#838161
Simplified wiring diagrams by loudhvx. KZR topic >> bare bones for mattylight >> Pg 1 .
Using an internet search, there's a 79 750B on pg 18.
A few of the diagrams may be missing. pages 11-on seem to have the most diagrams.
There are others for the 750B models & at least one of which is batteryless.
You can do stock type crimps with the proper terminals & bullet connectors using an open barrel crimper >> the crimps are very strong.
Z1Enterprises.com has electro supplies & color wire. CycleTerminal.com is where I got my electrical connectors, terminal pins, etc. & they have a nice terminal pin tool set. Both places have a good crimper.
Last edit: 06 Nov 2020 06:12 by martin_csr.
