1976 Z900 Wiring harness routing
- daz3226
28 Oct 2020 10:32
Hi al ,
I am looking for advice on routing the wiring harness\loom Bach through the frame.
Any links to diagrams or photo series ?
Thanks in advance of any help .
Regards Daz
Regards Daz
1976 z900 1
Re: 1976 Z900 Wiring harness routing
28 Oct 2020 20:22
If you're trying to do the main harness this should help. The harness mounts to the left tank tube, with the Y located just behind the left coil. The Y crosses over for right handlebar plugs. The main harness dives under the tubes and runs down the right rear downtube.
Attachment IMG_1512.jpeg not found
The following user(s) said Thank You: daz3226
- Rick H.
02 Nov 2020 05:48
Not to steal the thread here, but is that how the main harness ran on a '77 KZ-1000A1? The reason I ask is that my main harness runs along the bottom of the top frame tube. I am just wondering if someone relocated the harness at some point. Thanks...
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
