KZ1000 wiring harness.
  • TerryK
  • TerryK's Avatar Topic Author
19 Oct 2020 17:34
#837267
Z1 Enterprises no longer stocks a new harness did the 77’ KZ1000. Anyone know another source for a good harness?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • hardrockminer
  • hardrockminer's Avatar
Re: KZ1000 wiring harness.
19 Oct 2020 18:29
#837272
It appears Z1 Parts have them.
z1parts.net/main-wiring-harness-kz1000-77-78/
The following user(s) said Thank You: Rick H.
  • TerryK
21 Oct 2020 17:00
#837416
I talked to them on the phone. They don’t.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Mikaw
  • Mikaw's Avatar
21 Oct 2020 17:14
#837418
TerryK wrote: I talked to them on the phone. They don’t.
Are you talking about Z1 Parts. I click the link HRM posted and its valid and you can even add it to a cart to complete the purchase. $115.00
  • jwfels
  • jwfels's Avatar
21 Oct 2020 17:30
#837421
part number 26001-145, niche-cycle, $95.80 good luck
Z1A AND 81 650
  • jwfels
  • jwfels's Avatar
21 Oct 2020 17:36
#837422
put the number up on ebay, more than 10 available
Z1A AND 81 650
  • TerryK
21 Oct 2020 17:55
#837425
Just did that for the third time. Nada
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • TerryK
21 Oct 2020 17:58
#837426
Z1 Enterprises. Added it to my cart and it says out of stock.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • hardrockminer
21 Oct 2020 18:12
#837431
There are two different companies. Z1 Enterprises and Z1 Parts. Have you tried both?
  • TerryK
21 Oct 2020 19:07 - 21 Oct 2020 19:12
#837442
None in stock on their web page, but finally found one on ebay.....from Niche Cycle lol
Found everything I need. Thanks for the help everyone!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 21 Oct 2020 19:12 by TerryK.
