speedometer gear housing
  • kz1000kz650
  • kz1000kz650's Avatar Topic Author
18 Oct 2020 11:53
#837165
Have a 1979 kz1000 LTD and taking apart front wheel . Speedometer gear housing looked good, but had very little grease.
How much grease should I put in there? It is off the axle.
2016 CTX700(Honda)
1990 cr500(restored 100%)
1990 cr250(restored 100%)
1979 KZ650 C3
1979 KZ1000 ST(shaft)
1979 KZ1000B LTD
  • martin_csr
  • martin_csr's Avatar
Re: speedometer gear housing
18 Oct 2020 13:57 - 18 Oct 2020 14:00
#837180
I lubricated mine the same way you'd pack wheel bearings. I used Bel-Ray marine waterproof bearing grease.
Last edit: 18 Oct 2020 14:00 by martin_csr.
The following user(s) said Thank You: kz1000kz650
