Installing a starter in a 1975 KZ400S
  • Triker05
  • Triker05's Avatar Topic Author
08 Oct 2020 18:05
#836432
I have a 1975 Kawasaki KZ400S and would like to install a starter in it. I have a parts engine that has the starter motor but no wiring. Is there a diagram/instructions available that shows what color wires go where and any constructive advice on issues I might encounter? Thanks!
  • TexasKZ
  • TexasKZ's Avatar
Re: Installing a starter in a 1975 KZ400S
08 Oct 2020 21:28
#836446
The following user(s) said Thank You: Triker05
  • Triker05
09 Oct 2020 11:24
#836469
Thank You! Very helpful, I appreciate it!
  • loudhvx
  • loudhvx's Avatar
11 Oct 2020 07:17
#836607
You are probably aware that you also need the starter clutch assembly from the parts motor. Your "S" motor came with a spacer in place of the starter clutch. Don't toss it, someone probably wants to buy it.
