Aftermarket switches - 1980 KZ440
- jlouis
07 Oct 2020 16:17
Aloha all! I am struggling with the search function on the forum, so I apologize if this has been asked a bunch.
Are there any recommended aftermarket or readily available switches that are similar to stock for left and right? The switches on my 1980 KZ440 are beat up and, I believe, beyond salvaging. I am fine with staying with stock switches, but most that I have found on ebay or similar look equally beat up.
Mahalo for any and all recommendations!
- Nerdy
Re: Aftermarket switches - 1980 KZ440
07 Oct 2020 17:37
Beat up how? Cosmetically or mechanically/electrically?
If the black plastic is now kind of ashy grey from the sun, there are products available (at any auto parts store) that will return them to a glossy black.
If the switches do not actually work, try disassembling them (just a little) and cleaning all the contacts with - you guessed it - contact cleaner.
If they are damaged - eg accidents, da kine - then aftermarket switches should work as long as they are for 3/4" bars and they include all of the functionality of the originals. For example, the one on the left will need hardware for high/low beam, horn, and turn signals. If you go the aftermarket route, you'll be on your own for the wiring.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Nebr_Rex
07 Oct 2020 20:15
Try Dime City Cycles . com
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
08 Oct 2020 06:04
Z1Enterprises.com has reproduction Z1 handlebar controls that might work. ~$40 each.
- VTEC
09 Oct 2020 17:41
Anybody know of a product to help sun-faded black plastic long-term? Everything I've tried only looks good until the next wash.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- gavroyer
14 Oct 2020 16:28
No eBay APP ID and/or Cert ID defined in Kunena configurationHere's a set on eBay too:
1980 KZ440-A1 LTD
- jlouis
28 Oct 2020 00:40
These look great, my current switches do not have the lights on/po/off function, would it be alright to just not wire that in?
gavroyer wrote: Here's a set on eBay too:
- jwfels
28 Oct 2020 06:48
hi, you can if you want, kx440 shows as a 4 pin connector, same as the replacement z1, you have to make sure wire placement is the same as your main harness, and correct as needed, move pins around, the other 2 leads on the new switch are to switch lighting, a single blue (feed) and double bullet (return), you have nothing to plug them into unless you break into the lighting circuit, should be plug and play good luck
Z1A AND 81 650
