Best stator and regulator?
- asphalt900
Re: Best stator and regulator?
20 Sep 2020 06:31
Ha, but it's a Global Marketing/Manufactured world these days, kinda hard to avoid. At least it's just the connector....maybe?
- VTEC
20 Sep 2020 06:43
OK. I'm sold. So I just cut off the two adapter harness connectors and splice into where the OEM connector is. 3 yellow to stator, red n black power and ground. What's the leftover sixth wire?
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
20 Sep 2020 08:27
Tape off the sense wire. It's not needed.
Stator wires straight into the R/R. Positive and negative output from the R/R into either the same connectors as the factory R/R or following the same path.
20 Sep 2020 08:28Really Ed? What device are you using to post this comment? A computer by chance? Or cell phone? Both have most components made in China.
China makes some of the top electronic devices in the world these days. You might want to educate yourself.
The following user(s) said Thank You: Mc Tavish
- Highway Magician
20 Sep 2020 09:13
Anyone know which wires go to these 2 terminals? I believe the three yellow wires go to the connector on the left. But what about the remaining 2 terminals?
Thanks.
Thanks.
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
20 Sep 2020 11:52 - 20 Sep 2020 11:57Nessism wrote:650ed wrote: I have never bought anything made in China that was worth 2 cents. Ed
Perhaps I am uneducated or maybe I've just had bad luck with stuff from China, but I wouldn't want to depend on Chinese stuff on my bike. Three K&N motorcycle oil filters from China were 3 different sizes, my computer from China had to be repaired because cards were not seated correctly and that caused a variety of problems, other items I bought were knockoffs rather than genuine and were not worth keeping, etc. I know many things I buy are not made in the USA, and I've never had problems with items made in Thailand or other foreign countries - only China. Coincidence or just bad luck? Maybe. Ed
Last edit: 20 Sep 2020 11:57 by 650ed.
20 Sep 2020 12:34 - 20 Sep 2020 12:36
This is something I put together for the Suzuki GS guys but it pretty much applies for KZ bikes too. Ideally the + output will split with one leg feeding the bike and the other heading over to the battery with a fuse inline.
SH775 Install
by
nessism
, on Flickr
Last edit: 20 Sep 2020 12:36 by Nessism.
The following user(s) said Thank You: Highway Magician, Street Fighter LTD
- 750 R1
20 Sep 2020 15:05 - 20 Sep 2020 15:05
Hi Ed, I have no doubt there are bad parts coming out of China, but there is plenty of good too, you need to know what you are looking for. I've been buying parts from China for years, I recently ordered a longer set of fork tubes for my 45mm showa forks so they would be at stock Kawasaki length, The quality is excellent and they were extremely well priced, I also bought a rear 4 spot caliper made from 6061 T6 billet aluminium for my rear brakes, It was insanely cheap and beautifully made, it looks exactly like a brembo P234 Supersport rear caliper and is just as well made, the bolts are the only difference to the brembo. My friend has bought the exact same rear shocks that Daftrusty here used on his beautiful KZ750FX replica build, again first class quality, and with preload, rebound and compression adjustment, again these are basically an Ohlins copy but a a fraction of the price, My friend is a mechanical engineer that has built and raced bikes for 50 years and he loves them, we pulled them completely apart and couldn't find fault, at nearly 1400 dollars {AUD} cheaper than the equivalent Ohlins, they are a massive bargain. Your computer problem is common and really has nothing to do with China, My cards have come loose a couple of times from moving my computer, easily fixed for nothing, they can come loose in transport, your computer was probably assembled in the USA anyway... Don't be too quick to write of China....
Sorry for the hijack...
Last edit: 20 Sep 2020 15:05 by 750 R1.
- VTEC
20 Sep 2020 15:55
Rick's stator, Polaris rectifier/regulator, and Triumph harness are in the mail. I'm working on a Kawasaki, right?
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- Highway Magician
20 Sep 2020 19:02VTEC wrote: Rick's stator, Polaris rectifier/regulator, and Triumph harness are in the mail. I'm working on a Kawasaki, right?
Nope. VTEC = Honda. :laugh:
Do you have a link for the Triumph harness?
Here's one.
www.bikebandit.com/oem-parts/detail/triumph/t2500676/b2746333
- VTEC
23 Sep 2020 08:40 - 23 Sep 2020 08:41
The harness from Bikebandit is two to three weeks out.
These guys have it in stock. 3-4 days USPS. Overnight FedEx for an extra $12.
www.triumphestore.com/p/43491948/T2500676.html
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
Last edit: 23 Sep 2020 08:41 by VTEC.
