EI for a 74 Z1
- [email protected]
EI for a 74 Z1
06 Sep 2020 22:24
Seeking advice on install of electronic ignition on my 74-Z1, is Dyna S a good option or is there better on the market, would 3 ohm coils be the right choice?
thanks
thanks
Re: EI for a 74 Z1
07 Sep 2020 06:00
Dyna S is a proven setup. It's designed to use coils from between 3-5 ohms.
Re: EI for a 74 Z1
07 Sep 2020 10:47
If you still have your original coils they should be 3.8 ohm. Dynatek makes a replacement...I think it's the green coils. They are the match for the Dyna S ignition.
