KZ650 electronic Tach
- 750 R1
30 Aug 2020 17:46
Did any of the later KZ650's have an electronic Tach ? I'm thinking about dropping my GPZ750 R1 cams into my sons 1981 KZ650 {710 kit} , the R1 cams have no tach drive so I'd need to swap out the cable tach for an electronic one. We would like to maintain a stock look if possible .
Re: KZ650 electronic Tach
31 Aug 2020 06:20 - 31 Aug 2020 06:41
No. Is this a 650-CSR? If so, the meters are the same size as the 750M Twin, 750H Ltd & 1000M, but they all have cable drive tachometers. and they're bigger than most other KZ meters. just an fyi.
Last edit: 31 Aug 2020 06:41 by martin_csr.
The following user(s) said Thank You: 750 R1
- 750 R1
31 Aug 2020 16:45martin_csr wrote: No. Is this a 650-CSR? If so, the meters are the same size as the 750M Twin, 750H Ltd & 1000M, but they all have cable drive tachometers. and they're bigger than most other KZ meters. just an fyi.
Thanks for the reply Martin. Its a Z650 F2, 1981 model {Australia} Its the same as the blue one half way down the page in the link below...
www.motorcyclespecs.co.za/model/kawasaki...asaki_z650f%2082.htm
