KZ650SR Ignition Points - Screws
- Evobobber
21 Aug 2020 02:02
Hi, I am trying to sort a 1978 KZ650SR non-runner. The screws holding the points on are pretty chewed up. i would like new ones before removing the old.
Anyone know what size screws are needed? Any help or advice would be welcome.
Thanks guys
Thanks guys
Re: KZ650SR Ignition Points - Screws
21 Aug 2020 02:40
Metric M4 x 8 mm (length)
21 Aug 2020 05:48 - 21 Aug 2020 07:19
For future reference many fastener sizes are listed in the parts diagrams.
Kawasaki.com. Cmsnl.com. or Partzilla which is the easiest to use.
Last edit: 21 Aug 2020 07:19 by martin_csr.
- Evobobber
21 Aug 2020 06:08
Never seen Partzilla before. Very impressed.
Thank you
Thank you
- Evobobber
21 Aug 2020 08:21 - 21 Aug 2020 08:21
Just in case you are not aware of it - there are no phillips screws on any KZ. Those cross headed screws that look like phillips are actually Japanese Industrial Standard (JIS) and using a phillips screwdriver on them will damage them becasue the screwdriver will not seat properly in the screw. You can very easily make JIS screwdriver tips from phillips tips - just ask if you need any instructions on how to do it. Ed
HOME MADE JIS BIT
HOME MADE JIS BIT
Last edit: 21 Aug 2020 08:21 by 650ed.
