92026-1031 Thrust washer size question..
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
19 Aug 2020 02:04
#833182
Does this thrust washer sit perfectly within the recessed area that's located just before the starter clutch needle bearings? Or is the bearing smaller than the recessed area? Please lmk. TY
1982 KZ1100D1
  • zed1015
  • zed1015's Avatar
  • Away
Re: 92026-1031 Thrust washer size question..
19 Aug 2020 03:12
#833187
Pics needed.
  • Gdailey2112
  • 82 KZ1100D1
20 Aug 2020 23:55
#833380
Found these dimensions listed as a spacer 25x38x1.0 Is that metric?
1982 KZ1100D1
  • kevski
  • kevski's Avatar
21 Aug 2020 00:01
#833381
If you are talking about the bronze washer the answer is yes to metric sizing, and they only go on one way round,
  • Gdailey2112
  • 82 KZ1100D1
21 Aug 2020 23:16
#833472
So it'd be: 25mm x 38mm x 1 mm?
1982 KZ1100D1
  • martin_csr
  • martin_csr's Avatar
22 Aug 2020 06:49
#833479
Yes, it's metric.
The following user(s) said Thank You: Gdailey2112
