Riding with turn signal on
- ckahleer
03 Aug 2020 11:09 - 03 Aug 2020 11:12
Has any one had success converting their turn signal switch to momentary contact? On my XT225 I was able to put small foam blocks on each side of the switch slider, making the switch turn off when released. I tried the same thing on my 82 KZ305, but the switch is to stiff and that trick didn't work. I find myself riding with turn signal on too often.
or
Is there a way to make them self canceling?
or
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
Last edit: 03 Aug 2020 11:12 by ckahleer.
Re: Riding with turn signal on
03 Aug 2020 11:15
Ginkgo Biloba?
- ckahleer
03 Aug 2020 12:06You whipper snappers wouldn't understand.Mikaw wrote: Ginkgo Biloba?
OLD LIVES MATTER.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
03 Aug 2020 15:00
Thanks for the compliment. Didn't think that at 57 I'd still be a Whipper Snapper.
- F64
- 81-KZ440D2
03 Aug 2020 16:04 - 03 Aug 2020 21:26
I've taken out the detent on mine.
I've also has a Smart Turn System unit- safer-turn.com/ . When the unit works it works really well. It'll when sense when you lean the bike over for a turn and shut off a couple seconds afterward and when you are still it remains on. The problem I had with mine was it would shut down...then i would have no turn signals. I may have gotten a dodgy unit but now I just use my m-unit to do the cancellation.
If you do buy the STS(2 year warranty), get it from A&J cycles or a dealer that is local as shipping the unit back to Slovenia gets expensive. Unless, you are in Europe already.
Anyway, I was also going to install a waterproof piezo speaker so i could actually hear the turn signal was on..but I got one that was wayyyy too loud.
www.floydbell.com/parts/UB09628SSD
So that speaker sits in the toolbox now with the STS.
You should be able to open up you switch and remove the detent. Send us a picture of the inside of the switch and we'll try to figure it out.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 03 Aug 2020 21:26 by F64.
