KZ750 Twin starter issues
  • Ramchargerjay
  • Ramchargerjay's Avatar Topic Author
26 Jul 2020 07:14
#831481
1977 KZ750 Twin. My starter will make the typical electric motor wine like it’s turning, but the output gear does not turn the chain. I’ve disassembled the output end of the starter and everything appears to be ok. Will it make that sound even if it’s not actually turning over? Or is there something else that could be wrong?
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ750 Twin starter issues
26 Jul 2020 11:27
#831504
Are you sure the chain is not moving? Usually, the starter clutch is the problem. The starter motor and chain crank like crazy, but the clutch fails to engage, so the crankshaft does not turn.
If the chain really is not moving when the motor is, then it could be that the splines on the output shaft or the small sprocket have been sheared off, or the reduction gears could be stripped.
Has this problem been a long time developing, or did it come on suddenly?
  • Ramchargerjay
26 Jul 2020 13:02 - 26 Jul 2020 13:14
#831514
I tried it with the stator cover off. It moves slightly then stops but keeps whining. All the gears look fine, nothing stripped, came on suddenly after sitting for almost two years.
Last edit: 26 Jul 2020 13:14 by Ramchargerjay.
  • TexasKZ
  • TexasKZ's Avatar
26 Jul 2020 14:47
#831519
Welp, my guess would be that something has gone amiss with the reduction gears, which live inside the starter.
  • Ramchargerjay
08 Aug 2020 07:04
#832406
I took the starter apart, and ring gear that the planetary gears sit inside spins in the housing. I don’t see how they made it to stay still in the housing, though.
