Is my new battery now fried ?
  • Ninja1195
  • Ninja1195's Avatar Topic Author
22 Jul 2020 18:54
#831242
Ordered a new battery for my recent '78 KZ650B and it arrived today. I was excited to finally fire up the bike after purchasing it two weeks ago.
Installed the battery and zero voltage! Connected my intelligent battery charger and after 30 minutes (on a whim) disconnected the battery and pulled it out. Total dry! The dealer neither installed the electrolyte nor supplied it in the box!
Needless to say I will run back tomorrow when they open but a quick google search says that my present battery is finished even if the dealer tops it off ?
Thoughts ?
1978 KZ650 B2
  • loudhvx
  • loudhvx's Avatar
Re: Is my new battery now fried ?
22 Jul 2020 20:39
#831246
If it was totally bone dry, without any acid, and never had any, then it should be fine. I can't imagine why it would be damaged. It would act a an open circuit. No current would flow. To confirm: connecting the battery should have produced no effect of any kind... as in there should have been no lights of any kind and no sounds.
The following user(s) said Thank You: Ninja1195
  • hardrockminer
  • hardrockminer's Avatar
23 Jul 2020 05:04
#831254
I agree with loudhvx. I'm wondering where you found info suggesting the battery would be useless if hooked up without acid?
  • martin_csr
  • martin_csr's Avatar
23 Jul 2020 07:29
#831261
This is a wet cell battery, correct? And it didn't come with an instruction sheet? If you don't know anything about batteries, then you should have at the least asked the dealer what needs to be done.
  • Mikaw
  • Mikaw's Avatar
23 Jul 2020 08:51
#831265
Somethings not making sense... I can’t recall seeing a battery sold dry that didn’t including the acid...
  • davido
  • davido's Avatar
23 Jul 2020 09:13
#831268
To my understanding, if you buy a battery on t'interweb,they will send it out dry with the acid seperate in a special dispenser. Probably for safety reasons during delivery.
Also,Im pretty sure the last battery I bought from my local bike shop was dry when he took it off the shelf, then he filled it up for me to take away.
That couldve all been a dream though!!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Jul 2020 09:22
#831269
Motorcycle batterys are sold dry with an acid fill up set included for safety reasons.
  • martin_csr
23 Jul 2020 09:59 - 23 Jul 2020 10:04
#831271
By Mikaw: ... I can’t recall seeing a battery sold dry that didn’t including the acid...
Same here, in the stores anyway. Some on-line sellers don't include the electrolyte. Z1Enterprises doesn't, at least not for the Yuasa wet cell battery for my motorcycle.
Last edit: 23 Jul 2020 10:04 by martin_csr.
23 Jul 2020 09:59 - 23 Jul 2020 10:00
#831272
Mikaw wrote: Somethings not making sense... I can’t recall seeing a battery sold dry that didn’t including the acid...
Some batteries are sold online without the acid being included (see www.amazon.com/Yuasa-YUAM2210Y-YB10L-A2-...id=1595523458&sr=8-1 ). That's not a big deal though since one can buy the battery acid at car parts stores. I did this myself and found it not to be a problem at all. Ed
Last edit: 23 Jul 2020 10:00 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
24 Jul 2020 08:17
#831330
This whole discussion looks like a convincing argument for buying an AGM battery. B)
  • 73z1
  • 73z1's Avatar
24 Jul 2020 09:53
#831338
>>>>>>>>>>>>>>Installed the battery and zero voltage! Connected my intelligent battery charger and after 30 minutes (on a whim) disconnected the battery and >>>>>>>>>>>>>>pulled it out. Total dry! The dealer neither installed the electrolyte nor supplied it in the box!
Your battery is ok, have dealer fill with acid, trickle charge twelve hours.
Thoughts ?
The following user(s) said Thank You: hardrockminer
