Starter Clutch chain came off
  • shroomcore
  • shroomcore's Avatar Topic Author
18 Jul 2020 06:05
#830907
Bit of a weird issue here and I'm not exactly sure how it happened. I came out to replace my left side cover gasket. When I took the cover off I realized the chain was off. I've attached a video below:
VIDEO
I suspect my dumbass brother was out here messing with it, but getting him to fess up is another issue..
Is there a way to get the chain back on without pulling the flywheel etc? I tried cranking it with a socket on the flywheel bolt and it fed the chain back around most of the way, but not completely. It's now pretty stuck in that position, wondering if it just needs to be disassembled at this point.
  • TexasKZ
  • TexasKZ's Avatar
Re: Starter Clutch chain came off
18 Jul 2020 07:04
#830912
Seems like to me that you should be able to remove the starter sprocket, reinstall the chain and put the sprocket back on. If ere is not enough chain slack for that, you should be able to loosen the starter motor and tilt it a bit to get the sprocket back on.
  • gavroyer
  • gavroyer's Avatar
20 Jul 2020 12:06
#831062
KZ400?
If so, then you may have to unbolt the starter motor and slide it towards the clutch-side of the engine. Also slide the sprocket off of the starter motor shaft. Run the chain around the starter clutch sprocket and thread the starter motor sprocket onto it as well, then you should be able to reinstall the sprocket on the starter as you slide the starter back into place. It is not necessary to completely remove the starter.
1980 KZ440-A1 LTD
