1982 KZ 550H Break lights turn signals and flashers work but no running lights?
  • Nathanb
  • Nathanb's Avatar Topic Author
22 Jun 2020 21:15
#828706
My running lights don't work. Brake lights and turn signals work . Running lights in front work . Running lights in back don't work. I think the license plate light is part of running lights.
Re: 1982 KZ 550H Break lights turn signals and flashers work but no running lights?
23 Jun 2020 03:58
#828710
Nathanb wrote: My running lights don't work. Brake lights and turn signals work . Running lights in front work . Running lights in back don't work. I think the license plate light is part of running lights.
What running lights in the back? As far as I know there are none on a Kawasaki. The turn signals in the back are just that - turn signals. The turn signals in the front have 2 filaments - one is for running lights and one is for turn signals. It sounds to me like your bike is working as designed if the license plate light is working. If the license plate light is not working check the bulb and the wiring. Ed
  • Mikaw
  • Mikaw's Avatar
23 Jun 2020 04:58
#828712
I checked and appears 650ed is correct. Your bike is a typical kz without any running lights within the rear turn signals. They are just turn signals. There are single filament bulbs in the turn signal housings. The only running lights in the rear come from the tail light. The license plate illumination comes from the clear bottom section of the rear taillight lens.
Based on your description sounds like everything is normal.
  • loudhvx
  • loudhvx's Avatar
23 Jun 2020 19:41
#828806
If the tail light is not turning on, check the bulb first. The tail light has it's own dedicated circuit going back to the ignition switch in order to incorporate the parking-light feature. The tail light is on with the bike turned off when the key is turned all the way to the "P" position.
  • Nathanb
13 Jul 2020 19:09
#830611
No light on license plate. It does have a clear panel for the license plate dual filaments on bulbs only one film it's working the brake filament.
  • Mikaw
  • Mikaw's Avatar
13 Jul 2020 19:56
#830612
Have you checked fuses and bulbs? Do you have a test light or an ammeter?
