Truck Lite 27270C LED Headlight Installation
- daveo
09 Jun 2020 19:01
Need some helpful advice...
Last year I fit a Truck Lite 27270C headlight in my KZ1100. It fit very well physically, but not as well after that.
With the ignition-key turned on, the beam-out (white) indicator lamp would stay lit, and the (blue) high-beam indicator and the HI-LOW beams would inconsistently turn off when switched.
Rather than addressing this and correcting the problem at the time, I chose to remove the indicator bulbs from the tachometer, and leave it at that. But the inconsistent switching is still a problem.
Not sure how to fix this.
:blink:
:blink:
1982 KZ1100-A2/1170 sleeper 😀
- daveo
Re: Truck Lite 27270C LED Headlight Installation
14 Jun 2020 08:18
- F64
- 81-KZ440D2
14 Jun 2020 08:58 - 14 Jun 2020 11:49
I have that same light.
It sounds like a loose connection. Can you get it to happen when the bike is sitting still or does it happen when you hit bumps?
The beam-out indicator is a result of led's i'm guessing. I have that problem with my brake light indicator.
If it is affecting both high and low beams it is probably a loose ground, bad switch or 12v positive wire issue leading up to the switch. The 12v positive wires leading from the switch to the light are probably ok.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 14 Jun 2020 11:49 by F64.
- loudhvx
14 Jun 2020 17:07
It could also be the reserve lighting control module detects the LEDs as a burnt out filament under certain conditions, then switches over to the other filament.
You can bypass the reserve lighting unit by pulling it and jumping some wires in the connector.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: daveo, F64
- F64
- 81-KZ440D2
14 Jun 2020 19:37
reserve lighting control...i learn something new every day.
Thanks loudhvx!
Thanks loudhvx!
81-KZ440-D2.
LIC, NY
LIC, NY
- daveo
23 Jun 2020 09:58loudhvx wrote: It could also be the reserve lighting control module detects the LEDs as a burnt out filament under certain conditions, then switches over to the other filament.
Thanks, I suspected that component had something to do with it.
The following link might be helpful for others experiencing the issue. The fix is simple!
I chose to leave the device attached to the frame since it's in a confined space directly behind the engine.
www.vn750.com/forum/19-electrical/87625-...e-lighting-unit.html
The following user(s) said Thank You: loudhvx, F64
