77 KZ750 Twin starter problems
  • Ramchargerjay
  • Ramchargerjay's Avatar Topic Author
03 Jun 2020 19:58
#827258
My starter is too weak to turn the engine over fast enough to start. It sounds like it’s struggling. To make sure it’s not a connection problem I tried to start it with jumper cables running to my truck. Didn’t help it. Brushes look ok. I’ve looked for starters online. Are they really that expensive and hard to find? Are there any aftermarket options?
Re: 77 KZ750 Twin starter problems
03 Jun 2020 20:52 - 03 Jun 2020 20:53
#827264
Was the truck running? If so, not a good thing to do. Ed
Last edit: 03 Jun 2020 20:53 by 650ed.
  • Ramchargerjay
03 Jun 2020 21:31 - 03 Jun 2020 21:32
#827266
650ed wrote: Was the truck running? If so, not a good thing to do. Ed
No. And the battery negative on the bike was disconnected.
Last edit: 03 Jun 2020 21:32 by Ramchargerjay.
  • TexasKZ
  • TexasKZ's Avatar
04 Jun 2020 06:22 - 04 Jun 2020 06:23
#827283
Could be that the starter motor just needs a thorough internal cleaning. While you have it apart, you can inspect all the parts and decide if it is indeed the problem.
The factory service manual should have a pretty good section on the starter internals.
Last edit: 04 Jun 2020 06:23 by TexasKZ.
The following user(s) said Thank You: Ramchargerjay
  • Ramchargerjay
05 Jun 2020 15:32
#827389
Took it apart, thoroughly cleaned it, still does the same thing. Turns over slowly and makes a loud whining sound.
