front brake switch kawasaki 1980 e1
  • askrider
  • askrider's Avatar Topic Author
01 Jun 2020 07:09
#827063
Hello all hope you all keeping safe and can get out for a run does any one no where i can get a front brake switch kawasaki 1980 e1 from please in the uk
andy
  • martin_csr
  • martin_csr's Avatar
Re: front brake switch kawasaki 1980 e1
01 Jun 2020 07:56 - 01 Jun 2020 08:34
#827065
EB is probably the best source. NOS might be available. You can get the part number at Partzilla or CMSNL.com. Partzilla is easier to use & has a cross-reference which cmsnl might have as well. Cmsnl is the only place I know of that has the diagrams for some non-USA models.
Last edit: 01 Jun 2020 08:34 by martin_csr.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
01 Jun 2020 10:18
#827069
I did convert all my bikes with hydraulic brake Switches, trust me they will last longer as the mechanic acuated Switches.
They are availiable for single and double Banjo/straight or angled wire/ M10 x 1,00 and M10 x 1,25
Brake MC`s usually are M10 x 1,25
Clutch MC`s usually are M10 x 1,00
The following user(s) said Thank You: askrider
  • askrider
01 Jun 2020 12:54
#827082
Thank you
  • uncle nick
  • uncle nick's Avatar
01 Jun 2020 13:15
#827083
Wemoto are usually good for the generic stuff. They list one here:
www.wemoto.com/bikes/kawasaki/z_750_e1/8...light_switch_-_front
Don't know if it's the one you need though.
1981 KZ650 CSR
