Battery connected backwards ‘81 kz750 LTD
  • Smudgeurself
  • Smudgeurself's Avatar Topic Author
  • IG: Smudgeurself
31 May 2020 18:27
#827045
I recently bought a kz750 Ltd.
Problem is, the guy I bought it from connected the battery backwards. Result of that was a wire caught fire and I was wondering what problems could result from connecting your battery backwards on a kz750 and what should I do to problem solve this? Any help would be great appreciated!
  • martin_csr
  • martin_csr's Avatar
Re: Battery connected backwards ‘81 kz750 LTD
01 Jun 2020 07:59 - 01 Jun 2020 08:35
#827066
There's a warning in the 81 KZ650 manual that says the zener diode in the voltage regulator can get burned out. I don't know if the igniter or any other component would be affected. some other parts with circuitry that might be affected include the turn signal operating switch, reserve lighting device & fuel check switch.
If the reg-rec is shot, you can use one from a Ninja 250/500 or Vulcan 500 up to at least about 2009 (credit to loudhvx). These are virtually identical to the stock unit. on some of them the connector is reversed, so you'd have to change out the terminal pins.
Last edit: 01 Jun 2020 08:35 by martin_csr.
The following user(s) said Thank You: Smudgeurself
  • Smudgeurself
  • IG: Smudgeurself
01 Jun 2020 21:52
#827107
I appreciate the help! I checked some wiring today and it looks like my reg did get burnt from the mishap. I will have to follow the wires a bit more to see what other components were hurt by this.
Once again thank you! This is my first bike and I’m really excited to get this bike back on the road.
  • martin_csr
02 Jun 2020 07:14
#827119
Maybe you have it already, but there's a 750-4 pdf FSM available.
  • Smudgeurself
  • IG: Smudgeurself
04 Jun 2020 19:43
#827326
I’ve talked with another kz750 owner over Instagram and he had emailed me the PDF for this bike. I appreciate the help though!
