Coil wire getting hot
  • 1981kz750ltd
  • 1981kz750ltd's Avatar Topic Author
28 May 2020 14:33
#826765
I' m working with a 1976 900 LTD with a wiring harness from a 1979 1000cc ( I don't know if it was an LTD). Problem is the coil feed wire ( yellow with red stripe) is heating as is the red wire from the ignition switch coming from kill switch/start button. Using the Dyno coil setup. Any solutions for resolving this? Thanks.
  • 73z1
  • 73z1's Avatar
Re: Coil wire getting hot
28 May 2020 15:34
#826770
The coils are drawing more amps then the wire can supply without over heating.
Either the coil loop has shorted or the coils need a larger wire.
Check if coils are same temperature or differ.
The following user(s) said Thank You: 1981kz750ltd
  • Mikaw
  • Mikaw's Avatar
28 May 2020 20:02
#826790
Check the scotch lock connection from the red wire of dyna pick ups, to the yellow with red. It could be a bad connection. Check voltage at the coil positive where the yellow/red connects. The dyna s are power hogs. Could also be in the ignition switch. The solder connections go bad
  • cb900f
  • cb900f's Avatar
28 May 2020 22:38 - 28 May 2020 22:40
#826801
Check to see that the coils have the proper input resistance and (assuming resistance is correct) if the coil input is shorting to ground via the coil's iron core laminations.
Last edit: 28 May 2020 22:40 by cb900f.
  • Mikaw
  • Mikaw's Avatar
29 May 2020 14:08
#826873
Not sure what model you have but this will help you test the coil for proper ohms
  • 1981kz750ltd
10 Jun 2020 16:10
#827807
Thank you for all the input. To follow up someone had previously repaired the handlebar kill switch with JB Weld which I believe has a lot of graphite in it. As it deteriorated the powdered JB Weld shorted the wires in the kill switch. Have repaired again with JB Weld clear epoxy.
  • F64
  • F64's Avatar
  • 81-KZ440D2
11 Jun 2020 08:37 - 11 Jun 2020 08:38
#827875
JB weld should not be conductive.
screenshot via www.jbweld.com/faqs
81-KZ440-D2.
LIC, NY
Last edit: 11 Jun 2020 08:38 by F64.
  • 1981kz750ltd
12 Jun 2020 21:56
#828033
Whatever it was I can only surmise. Grey epoxy like material deteriorated to the degree it was causing a short. Whatever it was is now gone and no more short.
  • F64
  • F64's Avatar
  • 81-KZ440D2
12 Jun 2020 22:23
#828035
are you still having issues with the coil wire getting hot?
81-KZ440-D2.
LIC, NY
  • 1981kz750ltd
13 Jun 2020 07:17
#828046
No. Wire heating problem is gone.
I've attached a picture of the inside lower half of the kill switch. Left side of the round disc that supports the brown and yellow/red kill switch wires show evidence of damage repair and partial remains of whatever substance was used to repair it. This repair substance had deteriorated and become powdery, apparently causing the short.
However.
There could be an alternative or additional cause or factor contributing to the kill switch short circuit.
For those of you who have yet to experience the joy of disassembling and reassembling these kill/run switches, they contain 3 tiny springs with a tiny ball bearing atop each one. Is it possible that after 44 years one of these little ball bearings deteriorated to the degree that its rust or flakes contaminated the switch internally, creating the short?
Or, did the previous party who repaired the broken disc not reassemble it correctly and one escaped its detent position, causing the short? Because I found only two when it came apart. But, they are tiny so it could have gotten away upon dissambly.
I'd suggest to anyone taking one of these apart, do it inside a plastic bag. if the springs or balls drop out they're contained in the bag.
Btw. These little ball bearings you can get at a good hardware store. :)
  • 1981kz750ltd
13 Jun 2020 07:23
#828048
However.
  • F64
  • F64's Avatar
  • 81-KZ440D2
13 Jun 2020 08:19
#828051
Good job!!!
81-KZ440-D2.
LIC, NY
