Kz750n spectre pulse coil
  • tylerb
  • tylerb's Avatar Topic Author
19 May 2020 13:17
#826101
I recently bought an '82 spectre 750. The guy I bought it from had pulled the pulse coil off for another project he has. I am having trouble finding the part I need. Any insight would be greatly appreciated. Pictures would be perfect!
  • TexasKZ
  • TexasKZ's Avatar
Re: Kz750n spectre pulse coil
19 May 2020 17:06
#826112
Partzilla says it is no longer available new, but you can use the part number (the whole thing) to see if any pop up online.
www.partzilla.com/catalog/kawasaki/motor...re-kz750-n1/ignition
  • loudhvx
  • loudhvx's Avatar
19 May 2020 17:32
#826114
You can use one from a Kz550, 650, or 750. The wire lengths might be different but the plate and pickups should be compatible. Just make sure they look like the ones in the link below.
s3.amazonaws.com/gpzweb/Ignition/PickupA.../PickupAndRotor.html
