Single phase wiring?
- Richyg4789
11 May 2020 14:53
Does yellow wire orientation matter from stator to rectifier? 78 kz650 black to ground red white to battery. Rewiring the entire bike plugs long gone. Also should I fuse the positive lead to the battery? Doesnt appear to be from the factory.
- Richyg4789
- z1kzonly
Re: Single phase wiring?
11 May 2020 16:28 - 11 May 2020 16:28
All wires off of stator are yellow and wired inline for AC current out. I am going by Z1/KZ. Sure others are same.
Funny thing! I am an old Shovelhead HD Guy. And in the Older HD Factory Manuals, the test for the stator says unplug wires coming out of engine case. Then hook up a 50-75 watt 120v light bulb, run engine and test the wires from the stator. If the light bulb works. You know the stator is working and producing AC power.
Good Luck!
Good Luck!
Last edit: 11 May 2020 16:28 by z1kzonly.
