1982 KZ 550H Break lights turn signals and flashers work but no running lights?
- Nathanb
22 Apr 2020 02:24
Break lights turn signals and flashers work but no running lights? Anyone have this problem? Help.
Re: 1982 KZ 550H Break lights turn signals and flashers work but no running lights?
22 Apr 2020 06:07 - 22 Apr 2020 06:25
Could be the wrong bulbs. The turn front signal / running light combo use a dual filament bulb, while the rear turn signal only requires a single filament bulb.
Last edit: 22 Apr 2020 06:25 by TexasKZ.
The following user(s) said Thank You: Nathanb
22 Apr 2020 06:53 - 22 Apr 2020 16:41
Is the motorcycle new to you? Is this a new problem or what? Did you change the bulbs?
Last edit: 22 Apr 2020 16:41 by martin_csr.
- Nathanb
22 Apr 2020 10:22
Every light works except the second stage of break and tail light. I checked bulbs with volt meter . They seem to check out.
- Nathanb
22 Apr 2020 10:28
I am going to replace them today. I will let you know. I would feel very stupid if so. Thank you.
- Nathanb
22 Apr 2020 10:30
Yes , Yes and No
22 Apr 2020 10:40Nathanb wrote: Yes , Yes and No
FYI, for this kind of post, the Quote button should be used so the rest of us, who do not live in your head, can know which post this refers to.
22 Apr 2020 13:22 - 23 Apr 2020 07:46
Sorry, I don't know what you mean by the second stage of brake light & tail light.
And earlier you said only the running lights aren't working. still not sure if your running lights were working beforehand or not.
On USA models only the Fr turn signals have running lights >> each Fr turn signal should have 2 wires plus a ground wire & the bulbs should have 2 filaments. The Rr turn signals are 1 wire plus ground wire & the bulbs have 1 filament.
Your GPz 550 tail light assy should have 2 bulbs & each bulb has 2 filaments >> 1 filament in each bulb is for the tail light & the other filament in each bulb is for the brake light. There's probably a tail light fuse.
Last edit: 23 Apr 2020 07:46 by martin_csr.
- Nathanb
22 Apr 2020 13:39
Yes it is a new project but I had a GPZ in my past.
