Resistor ignition coil z1000 mk2
  • Giorgio85
  • Giorgio85's Avatar Topic Author
15 Apr 2020 14:24
#823447
Good evening, I am a new user and I am writing to you from Italy. I hope you can help. I bought a kz1000 mk2 to restore. I have a problem with the coils because they were not present. I purchased 2 new 4ohm coils. I have seen on the wiring diagram that there is a resistance. On various sites I have found 2 types of resistors: 20 w 0.5 kohm and 30watt 1.7 ohm. Which one should I buy for my bike?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Resistor ignition coil z1000 mk2
15 Apr 2020 16:15
#823449
AFAIK, 4 Ohm coils don“t need any ballast resistors.
The following user(s) said Thank You: Giorgio85
  • loudhvx
  • loudhvx's Avatar
15 Apr 2020 17:58
#823453
Like Scirocco said, the 4 ohm coils didn't use resistors. they were used on points-driven ignitions.
The early electronic ignition coils used ballasts, but only because the proper coils were not available. Nowadays you would just get 2.3 ohm coils and eliminate the ballast (most coils from 2.2 to 3 ohm will work and won't need a ballast). But that is only if you have electronic ignition.
  • Giorgio85
15 Apr 2020 21:53
#823461
Thanks for the replies. I have the electronic ignition on this bike.I can know from you how to calculate in the future if the resistor should put it or not put it?
  • hardrockminer
  • hardrockminer's Avatar
16 Apr 2020 05:18
#823473
If you don't know what resistance is in the coils you can measure the primary side. If 2 ohms then you need the resistor. If 4 ohms then you don't need it.
