New coil, New plugs, no spark
  • MadeupofWires
  • MadeupofWires's Avatar Topic Author
14 Apr 2020 19:12
#823393
I recently changed my coil and plugs with no luck. Bike still won't start. I've hooked a spark tester up and get spark within the "bulb." When I pull a plug and ground it against the engine, nothing. No real knowledge of electrical/ignition.
  • loudhvx
  • loudhvx's Avatar
Re: New coil, New plugs, no spark
15 Apr 2020 10:13
#823423
When you test for sparks, you have to make sure both plugs from the coil are able to complete a path to each other or to a common piece of metal.
That is, assuming your coil has two plugs connected to it.
It would help to know what bike we are dealing with.
  • MadeupofWires
16 Apr 2020 04:43
#823470
76 kz400. I leave 1 plug in the engine and pull the other and ground it against the engine. When I do this I was able to get 1 plug to spark a couple of times.
  • loudhvx
  • loudhvx's Avatar
16 Apr 2020 05:05 - 16 Apr 2020 05:06
#823472
I would take both out and lay them both on the head so you can see them both at the same time.
This will also make it a lot easier on the starter or kicking.
You didn't mention new points. That will be a big factor. If the points are pitted and dirty, it won't get consistent spark.
Last edit: 16 Apr 2020 05:06 by loudhvx.
  • MadeupofWires
18 Apr 2020 10:54
#823600
Just did it with 1 small spark on the left and then nothing on either. I assume my points are bad.
18 Apr 2020 17:29
#823620
I really don't think I understand. You did not perform a tune up on the bike, but instead you replaced the coil? Why not simply perform a tune up before replacing any parts that may be perfectly fine? Tune ups are a perfectly normal part of motorcycle ownership and must be performed periodically as documented in the Kawasaki Service Manual. Ed
