Key blank for 76 KZ900?
- CT5110
14 Apr 2020 13:30
undefined HI all....wondering how I can acquire an extra key for my bike. I have one original that came with bike when I purchased last year. Are there sources that you know of? Any suggestions welcomed. //CT
Re: Key blank for 76 KZ900?
14 Apr 2020 13:37
You can find blanks on fleebay, locksmith should be open as I’d consider security an essential business. They can cut a duplicate. Don’t want to post actual auction without seeing your key.
- CT5110
14 Apr 2020 14:09
Thanks for the prompt reply Mikaw. The key is #788. I see them on ebay for $75+ . So can I assume as long as it is the same key # that I will work? I can post photo if needed. //Craig
14 Apr 2020 14:34
No eBay APP ID and/or Cert ID defined in Kunena configurationYes as long as it’s the same number it should work. Here’s an cheaper option. Buy this and take to a locksmith shop and for less than $5 they can cut the blank to match.
The stamped number on the key won’t match the cut, just note that and maybe keep your original in the safe.
14 Apr 2020 14:37 - 14 Apr 2020 14:39
No eBay APP ID and/or Cert ID defined in Kunena configurationHere a cheaper cut key. Select you key number #788. Cost is $30.00 plus shipping
Last edit: 14 Apr 2020 14:39 by Mikaw.
The following user(s) said Thank You: CT5110
- BCScott
14 Apr 2020 15:02
ilco also makes blanks, if you're just looking for a spare that works. Any hardware store or locksmith should carry them. Mine has the number X54 DC1 on it.
Back in the saddle and loving it! KZ1000A1
The following user(s) said Thank You: Mikaw, CT5110
