Charging help please
- MartyZ1000
13 Apr 2020 21:23
Hi guys,
Hope you´re all ok in these scary Covid 19 times.
So my KZ1000 is suddenly not charging the battery.
The stator measures Ok both ohm-wise and AC output wise when running, and the bike runs great after a run-start or battery charged,
The rectifier/regulator measures ok ohm-wise too. And the gel battery is good as well, when using a charger it charges ok and keeps voltage
to 13V/24h.
The starter engine runs great with the battery charged, so there is no cut in +/- *from it*. I´m thinking it must be in the wiring?
And where would you start looking/measuring?
Greatful for any good ideas on this.
Keep safe--Martin
to 13V/24h.
Keep safe--Martin
- ckahleer
Re: Charging help please
13 Apr 2020 21:55
What voltage is at the battery at idle? What is it at 3,000 rpm?
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
- MartyZ1000
14 Apr 2020 00:00 - 14 Apr 2020 00:45
Just took the stator out today and I guess it is totally burnt? see attached photo...
Last edit: 14 Apr 2020 00:45 by MartyZ1000.
14 Apr 2020 08:48 - 14 Apr 2020 08:49
I don't know if that stator is normal. Is your generator dry or wet? Some models get wet with oil, since there isn't a seal on the end of the crankshaft & there's a hole for the oil to drain back down into the engine. My 81 KZ650 is dry & there's a crankshaft seal.
Did you load test the battery?
Last edit: 14 Apr 2020 08:49 by martin_csr.
- hugo
- '92 Zephyr 750
14 Apr 2020 14:49
...or you said the 'The stator measures Ok both ohm-wise and AC output wise when running'.....how did your measure that, and what were the readings?????
.....and what was the voltage output of the R/R when running?
