Turn signals on my 82 kz 750 turn on like an auxiliary but don’t flash
- randafal15
16 Mar 2020 21:28
So we bought a KZ750 Spectre and the person decided to go all freddy krueger on all the electronics and eliminated the front blinkers and disabled the rear blinkers in the process and we have enabled the front lights to turn on and the rear goes on and off however they don’t blink at all, we’ve replaced the Turn Signal Unit box, put new relays in, new battery, but the lights just stay on. We’ve cleaned and checked all connections. Any ideas?
Re: Turn signals on my 82 kz 750 turn on like an auxiliary but don’t flash
17 Mar 2020 06:49
Have you checked the Hazard (emergency) flasher circuit? He may have done something unexpected with it.
- randafal15
17 Mar 2020 10:54
yes we’ve gone through both at the same time
17 Mar 2020 11:59
Did the bike have normal bulb style blinkers or LED ???
old school flasher relays work only with bulb blinkers (21 Watt), they need a specific load (current) to work on/off.
LED blinker or LED bulbs inserts needs a load Independent( electronic ) flasher relay.
- deano68
19 Mar 2020 10:50
what colour wires are connected to the front indicators? grey and green are the indicator wires and i think blue is on the lighting circuit on USA models black with yellow stripe is earth
76 KZ 400
78 KZ 650
82 Z 750(4)
80 KZ1000 ltd project
82 CSR 1000 work in progress
78 KZ 650
82 Z 750(4)
