1982 KZ650 Right Housing Control
  • MikeyyD87
  • MikeyyD87's Avatar Topic Author
10 Mar 2020 12:27
#820686
I have a 1982 KZ 650 CSR. Seems like the right housing control is a hot commodity because the only ones I can find on ebay are over $100. Mine cracked and I am holding it together now with a zip tie. I would like to make it proper but can see spending $100 for a new one when all the other housing controls for every other year are around $40. Does anyone know where I can find one or I was thinking about an aftermarket one that will hold the same throttle tube. Also I have contemplated creating a CAD drawing for it and just 3D printing new plastics for it and reassembling it. Any other ideas?
-Mike DiMauro
  • calum
  • calum's Avatar
Re: 1982 KZ650 Right Housing Control
17 Mar 2020 10:05
#821083
Hi Mike. Do you have a picture of the cracked control housing? I can't find anything for part number 460911121. I may have something from my 750H.
  • martin_csr
  • martin_csr's Avatar
17 Mar 2020 11:32 - 17 Mar 2020 11:44
#821090
From the diagrams at Partzilla for the 1982 KZ650-H2 CSR, the RH handlebar control is part #46091-1155.
The cross-reference there lists a number of 82-on models that use the same part and a few 1981 models.
note: Kawasaki kind of lumps the parts for some models together, so a part listed for an 81 & 82 model, may actually only be intended for one of them, and I think that's the case with the part number I listed.
Last edit: 17 Mar 2020 11:44 by martin_csr.
  • calum
  • calum's Avatar
17 Mar 2020 11:40
#821091
Thanks Martin. I got the part number above from CMS. I imagine they are the basically the same part. I have a set of 46091-1047 that need some paint but are intact.
  • martin_csr
17 Mar 2020 12:02 - 17 Mar 2020 15:30
#821094
Weird. at Cmsnl.com the part number you listed is showing that it fits his motorcycle but the diagram drawing shows the earlier style metal housing control. But when I search the 650-H2, it's showing a different part number in the handlebar diagram w a drawing of the plastic handlebar control. This may be one of those cases in which the Kaw x-ref is wonky.
Last edit: 17 Mar 2020 15:30 by martin_csr.
  • calum
  • calum's Avatar
17 Mar 2020 13:56
#821105
Yeah, it can get a bit messy at times! If it's a plastic housing then that's me out. My spares are the old metal housings.
  • MikeyyD87
18 Mar 2020 08:31
#821155
I will try and get some pictures of it before the end of the week. Thank you
  • MikeyyD87
18 Mar 2020 08:31
#821156
It is the plastic housing. I will try and get pictures before the end of the week.
  • MikeyyD87
15 Apr 2020 08:24
#823416
Sorry guys it has taken me so long to post the pictures of the cracked piece.
