'81 KZ440 Signal Light LED Conversion
  • dsr9024
  • dsr9024's Avatar Topic Author
08 Mar 2020 14:22
#820562
So finally got around to swapping my signal incandescent bulbs for leds. Swapped the rear ones first and tried them out and they worked flawlessly swapped one of the fronts and boom now we just light up on that side but i can still switch the other side that has an incandescent and led mix. I did put in an electric/mechanical flasher relay so no hyper flashing. I've got a few more things to try but i thought i would see if i could narrow it down on here.
  • Mikaw
  • Mikaw's Avatar
Re: '81 KZ440 Signal Light LED Conversion
08 Mar 2020 15:30
#820566
I just finished an all LED upgrade to my 1978 LTD 1000, this worked for me. I cant take credit for finding it I found this in a pervious post.
www.superbrightleds.com/moreinfo/flasher...nic-flasher/779/833/
The following user(s) said Thank You: dsr9024
