ZX550 battery indicator
- Slashaguc
27 Feb 2020 22:15
Hi Guys,
Ive got an '85 GPz550 Unitrak (ZX550 A1) that has the battery electrolyte sensor on the fuel tank panel. However, I'm using a gel battery which does not have the sensor installed so the LED warning light flashes continually. How do I disconnect or stop this light from flashing?
Thanks in advance for your help.
Slash
Slash
Keep'er pinned, Tina!
- riturbo
Re: ZX550 battery indicator
28 Feb 2020 05:34
Hook the sensor wire up to the positive side of the battery . That will stop the blinking light .Had the same issue with my turbo when i put one of those batteries in .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: Slashaguc
28 Feb 2020 06:18 - 29 Feb 2020 06:34
The sensor wire is pink & there should be a black-white accessory wire, probably under the LH side cover near the electro stuff, so you could probably unplug the sensor & connect the pink wire to the black-white acc terminal. With any luck, the wires will be long enough & pink will plug right in. If not, you could make a short jumper wire. should be easy. There's probably other ways to do it.
ps: in the USA the ZX550-A1 is the 1984 model. The 85 would be the A2.
Last edit: 29 Feb 2020 06:34 by martin_csr.
