1978 Kawasaki kz650b ignition switch
- Soarin
23 Feb 2020 04:14
So I'm working on this kz650 from 1978 I believe, and like many other bikes the keys are lost. I thought oh yeah that's easy can just order another ignition switch right? Well I guess I must have the only kz650 with a 7 wire ignition switch cause every switch I find online is only the 6 or 4 pin connector. Anyone know where I can find one with the 6 pin connector and the 7th wire?
1981 Kawasaki Kz750h
Re: 1978 Kawasaki kz650b ignition switch
23 Feb 2020 09:12 - 24 Feb 2020 05:47
The motorcycle in the pic appears to be a 650C since it has triple disks. From the wiring diagrams a 78 should have a 6-wire ignition switch, but a 79 should have 7-wires, so your motorcycle might be a 79 model. note: as with most vehicles, the year of mfg isn't necessarily the model year.
You're probably going to have to use a 6-wire ignition switch & reconfigure the wiring a tad. The 1979 KZ650B/C wiring diagram shows a 7-wire ignition switch w 2 white wires. I'm not sure what wire from the harness you wouldn't use, but maybe a white since they're kind of redundant. just a guess. Z1Enterprises.com lists an Emgo 40-80600 ignition switch for the 79 650C, but I couldn't find a connection chart or wiring diagram for it. If you have a multimeter, you could test for continuity between the wires of the Emgo unit when it's turned to ON & to Park to figure out how the wire colors would match up with the ignition switch chart at the bottom of the 650 wiring diagram. White, red & brown probably match up, so you'd only need to figure out the other 3. I guess it shouldn't be too hard.
Last edit: 24 Feb 2020 05:47 by martin_csr.
The following user(s) said Thank You: Soarin
- gd4now
- Denco where did you go?
23 Feb 2020 09:30
Here are the part #s for the switches - from the Kaw site.
27005-083
4 leads on switch - 4 pin connector
KZ650-B1 (1977)
27005-5001
6 leads on switch - 6 pin connector
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
27005-5007
7 leads on switch - 6 pin connector and single wire
KZ650-B3 (1979)
Kz650-B4 (1980)
KZ650-C3 (Custom) (1979)
KZ650-C4 (1980)
KZ650-D2 (SR) (1979)
KZ650-D3 (SR) (1980)
KZ650-D4 (SR) (1981)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-F2 (1981)
KZ650-F3 (1982)
27005-5024 (supersceeded 27005-5015 27005-5017 27005-5027 27005-5035)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
27005-083
KZ650-B1 (1977)
27005-5001
KZ650-B2 (1978)
KZ650-B2A (1978)
27005-5007
KZ650-B3 (1979)
Kz650-B4 (1980)
KZ650-C4 (1980)
KZ650-F1 (1980)
KZ650-F2 (1981)
KZ650-F3 (1982)
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
23 Feb 2020 14:07 - 23 Feb 2020 14:07Soarin wrote: So I'm working on this kz650 from 1978 I believe, ....................
Please help me to understand how one can own a bike and not know what model year it is? Please don't think I'm being disrespectful - I'm not. I ask because you definitely are not the first person to not know this crucial information, so I am trying to understand why there is this confusion. It is very obvious to me by glancing at the photo that the bike is a 1979 KZ650-C3 (NOT 1978 - KZ650-C2), so what was it about the bike that made you suspect is a 1978? One other question - do you have a title for that bike and doesn't that show what model the bike is? Thanks. Ed
Last edit: 23 Feb 2020 14:07 by 650ed.
