Starter
  • MadeupofWires
  • MadeupofWires's Avatar Topic Author
Starter
11 Jan 2020 11:01
#816920
With the starter pulled should i be able to turn it by hand?
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Starter
11 Jan 2020 12:37
#816927
Unlikely as the ratios of the reduction gears in the starter gearbox will be working against you. Whilst you have it off regrease the starter gearbox as they do dry out and can become troublesome.
  • MadeupofWires
Re: Starter
11 Jan 2020 13:42
#816930
A little background: I purchased a used starter to replace mine after rebuilding it didn't work. The newer one worked but the ends were beaten up so i swapped them for my old ones. After putting it back together it doesn't work. I read online that you should be able to turn it by hand. I'm unable to do so.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: Starter
11 Jan 2020 14:34 - 11 Jan 2020 14:40
#816932
If you are asking about turning a cranking motor, off the bike, by hand...yes.... I good electric motor with no bad bearings, in one piece, yes.....you should be able to turn by hand. Because this is a DC motor with brushes rubbing on a commutator, you would feel resistance, but yes, ….it should turn.
I have a spare one in the shelf for a 750, and yes...I can turn it by hand.
Last edit: 11 Jan 2020 14:40 by hugo.
  • MadeupofWires
Re: Starter
11 Jan 2020 17:50
#816938
If it was working then taken apart to swap out the ends and now it isnt working, what could be the issue? The armature spins freely until I put the out drive on.
  • hardrockminer
  • hardrockminer's Avatar
Re: Starter
11 Jan 2020 20:31
#816944
The starter should turn easily. If it isn't turning then something is wrong.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
Re: Starter
12 Jan 2020 02:39 - 12 Jan 2020 02:39
#816952
A few reasons come to mind; Alignment, bolts too tight, parts out of order, out of place, or backwards, brushes jammed, some motors have shims.
Are the two motors you are swapping identical? You don't mention what type of bike this is. What is what you call the out drive?? The gear on the shaft??
Last edit: 12 Jan 2020 02:39 by hugo.
