2 cylinder KZ1000P
- Ckary
2 cylinder KZ1000P
20 Dec 2019 12:45
I know, I know.....I'm guessing it's the coil after reading every post I could find. 1 and 4 are hot, 2+3 are cold. It's new to me, and haven't even looked or tested anything yet. I'm not that sharp when it comes to electrical, but my Clymer's is already under the tree, and I'm ready to learn over the winter. Rode around the neighborhood, absolutely no power whatsoever, but it moved and stopped, even with my #260+ on it.
My real question is.....how does this thing run so smoothly at idle, while goosing the gas, and everywhere in between when it's not hauling me around?
67 Kawi 250? gone
78 Suzi GS550E - gone
83 Honda 750 Nighthawk-gone
2004 Kawi Concours-gone
1994 Harley Road King (2010)
2001 KZ1000P (2019)
2001 KZ1000P (2019)
Re: 2 cylinder KZ1000P
20 Dec 2019 15:08
Most likely a bad coil, or at coil is getting no power for some reason. It could also be a bad sparkplug in 2 or 3, preventing a complete circuit. The Clymer is ok, but you can download the basic 1981-83 KZ1000 factory service manual from KZR, and pick up the appropriate P-series supplement from fleabay. The factory supplement will be far more specific than the Clymer when it comes to your specific bike.
- ThatGPzGuy
20 Dec 2019 16:46
Make sure your 2/3 coil is getting 12Vs with the key on. If so, yeah, probably a bad coil although that is not that common.
You could swap the 1/4 and 2/3 coils to see if the dead cylinders follow.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
20 Dec 2019 18:20
I can't tell you how many times I've ridden home on two cylinders the last 40+ years.
The following user(s) said Thank You: Ckary
- tthunderdan
21 Dec 2019 04:53
When I got my KZ1100 it acted the same.
I put new plugs in it and about 6000 miles later, still going strong.
Dan from Slippery Rock PA,
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
83kz1100a
83spectre 1100
75 Yamaha DT400
75 Yamaha DT175
80 Yamaha MX80
81 Suzuki TS100
- Ckary
23 Dec 2019 08:05
Thanks for all the comebacks - can't wait to hear all 4 purring.
67 Kawi 250? gone
2001 KZ1000P (2019)
2001 KZ1000P (2019)
- Ckary
10 Jan 2020 13:23tthunderdan wrote: When I got my KZ1100 it acted the same.
Nailed it - I ordered 4 plugs and 2 cheap coils (before I read the coils weren't worth the postage). Checked spark from old coils to plugs. All plugs were receiving spark. Swapped out the plugs, fired up and rode around the neighborhood. It's going to be a fun spring.
I should probably think about getting the ol' girl legal now.
67 Kawi 250? gone
2001 KZ1000P (2019)
2001 KZ1000P (2019)
