Ignition Coil
- zachsnacks
Ignition Coil
01 Dec 2019 09:43
Alright, more tests and now I have caught a small smoking gun that I think it might be.
Bike came with aftermarket ignition coil that was replaced with this one - www.amazon.com/gp/product/B014WWNHGK/ref...01_s00?ie=UTF8&psc=1
initial one and new one are reading .3 primary resistance.
Manual states much higher.
Electronic ignition, not points if that matters, I have heard electronic can run less than 4 ohms.
Replace the ignition coil? And with which one?
Thanks in advance.
Thanks in advance.
1983 Kawaski 440 Ltd
I promise I wont make it a cafe racer if you help me out.
- 73z1
Re: Ignition Coil
01 Dec 2019 09:56 - 01 Dec 2019 09:58
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationAmazon sells junk made in China
Japan coils are good -
These are good -
These are good -
Last edit: 01 Dec 2019 09:58 by 73z1.
- zachsnacks
Re: Ignition Coil
01 Dec 2019 10:10
This is the one I got, that seems to be the problem -
Re: Ignition Coil
01 Dec 2019 10:57
.3 ohms is super low. Are you sure? Not 3 ohms? And what does your manual state? I don't know about the 440 but on my 750 the coils are supposed to be 1.8-2.8 ohms which is pretty low as far as '80s coils go.
- zachsnacks
Re: Ignition Coil
01 Dec 2019 11:57
.3 - 100% just triple checked it.
The secondary winding test registered correct, so I know the multimeter is working.
- loudhvx
Re: Ignition Coil
02 Dec 2019 09:48
On the lowest scale, touching the leads together might give a reading of .3 ohms. Are you sure nothing is shorted in the wiring that you are testing?
Like Nessism said, .3 is extremely low. I was also going to ask if you meant 3 ohms, but he beat me to it.
At .3 ohms you will destroy the igniter pretty quickly. So don't even try to use that coil. Hopefully the igniter is still good.
Also, at .3 ohms, I would have expected a fuse to blow or the igniter to smoke or the coil to smoke.
Like Nessism said, your coil should be in that 1.8 to 2.8 range. The target value is 2.3 ohms and most tend to be in the 2.3 to 2.6 ohm range.
A 4 ohm coil would be for points.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- zachsnacks
Re: Ignition Coil
03 Dec 2019 12:01
Thats what I thought too! But I swear .3, I am ordering a new one tomorrow. Keep you posted.
The secondary test came out perfect, so I know the multimeter is set correctly.
- baldy110
Re: Ignition Coil
04 Dec 2019 19:29
And the coil should also cost more than $18.00. That price to me is a red flag.
- zachsnacks
Re: Ignition Coil
05 Dec 2019 07:47
Right?! That was my first red flag, but I took a shot anyways. I think thats my smoking gun, I have ordered the new one coming from Japan.
If anyone has one that can come faster I would be very appreciative.
- zachsnacks
Re: Ignition Coil
11 Dec 2019 15:15
Brand new NGK ignition. Still missfiring at 3500-4000.
Any guesses left on the table?
Buddy of mine says replace the carbs.
Re: Ignition Coil
11 Dec 2019 16:55 - 11 Dec 2019 16:56
Maybe tell us what's been done to the carbs, and whether you have a stock intake and exhaust. Also, have you done a compression test and checked your valve clearance? Any photos of the carbs?
Last edit: 11 Dec 2019 16:56 by hardrockminer.
- zachsnacks
Re: Ignition Coil
11 Dec 2019 17:17
Sorry, I broke my initial thread and started this one, it was all included originally.
Stock air box, stock carbs, jets are all clean as a whistle, carb seals are all new and new diaphrams. Compression test done, it was a little on the low side but still within limits. Valves are done, battery has been tested with high beam test and load is showing 12.2
My initial smoking gun was the ignition coil being the wrong one but since being replaced its not the answer.
Last idea, the left side exhaust does not flow as strong as the right. (air to fuel mixture was taken back to zero and turned 2 and 1/4 turn out.) The right exhaust pipe hits my hand with exhaust puff leaving the pipe. The Left exhaust pipe has exhaust coming out but not with as much power, its a decent amount but weaker than the right.
