Magneto position, KZ440
- Onlybackroads
04 Nov 2019 18:14
Hey everyone first post here, just picked up a 1982 kz440 belt drive.
The starter stopped engaging so I decided to pull the cover and see what was up, turns out the flywheel/magneto bolt came loose and was just spinning the ring gear, not moving the flyheel/started clutch. Unfortunately this means the flywheel lost its position on the taper. Can anyone help in pointing out any information as to location the correct position of the flywheel in correspondence to timing? Thanks a lot, hope to get this thing going at some point!
-Sean
-Sean
- Nebr_Rex
Re: Magneto position, KZ440
05 Nov 2019 02:45
There is no set position, just tighten the bolt.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
