H4 bulb? Which terminal is ground?
- Kawidave
25 Oct 2019 07:14 - 25 Oct 2019 07:21
The best way I could diagram it. When looking at the bulb from the terminal side, which terminal is ground?
Last edit: 25 Oct 2019 07:21 by Kawidave.
The following user(s) said Thank You: Zedsded
Re: H4 bulb? Which terminal is ground?
25 Oct 2019 07:44
The following user(s) said Thank You: Kawidave
- Zedsded
13 Mar 2021 17:12
Thank you. That's just solved a long standing issue with my Z1B!
73 Z1
75 Z1B
75 Z1B
