I need a wiring diagram
  • Danamal131
  • Danamal131's Avatar Topic Author
21 Oct 2019 09:39
#812818
I need a wiring diagram to install aftermarket speedo tack on a 1980 csr 1000
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: I need a wiring diagram
21 Oct 2019 13:40 - 21 Oct 2019 13:57
#812825
What Kind of speedo you are talking about? Some electronic speedos could be some pain in the ass (bouncing needle) on old bikes.
Last edit: 21 Oct 2019 13:57 by Scirocco. Reason: add a picture of the tach/speedo
  • martin_csr
  • martin_csr's Avatar
21 Oct 2019 13:59 - 22 Oct 2019 05:44
#812826
There may be a youtube video for your exact speedo or something pretty much the same.
Your CSR may be a 1981 model. You can check the vin at Kawasaki.com or CycleChaos.com or check the model application chart on the back cover of the Kawasaki service manual. There's an 81-83 KZ1000/1100 FSM pdf w wiring diagrams & it may be linked in the filebase here on KZR.
note: the date of mfg isn't necessarily the model year >> as with any other vehicle mfg, some 81 models would have been made in 1980.
Last edit: 22 Oct 2019 05:44 by martin_csr.
