10A fuse source?
  • 2strokerider
  • 2strokerider's Avatar Topic Author
10A fuse source?
23 Sep 2019 22:37
#811247
Popped a 10A fuse yesterday. Actually it was a 7.5 A fuse in place of what should have been a 10A. I haven't seen any at the auto supply, bike parts places or at the Z1 website. Any ideas where I can get some 10 A fuses?
TIA
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 10A fuse source?
24 Sep 2019 02:24
#811249
I don´t know where are you located but LOUIS in Europa sells a set of five 10 A fuses for 1,99 Euro.
www.louis-moto.co.uk/artikel/glass-fuses-5-pack-30-mm/10031307
www.louis-moto.co.uk/artikel/glass-fuses-5-pack-25-mm/10031205
24 Sep 2019 05:51
#811256
You need to identify the fuse you need not just by the amperage but also the specific fuse number. For example, there are 10 amp fuses that have different lengths. So a fuse that is too long or too short won't fit your fuse holder. Take a look online and you should be able to find the correct fuse number for the exact fuse you need. The link below provides some info. Ed
knowhow.napaonline.com/know-how-notes-gu...to-automotive-fuses/
The following user(s) said Thank You: TexasKZ
  • TexasKZ
  • TexasKZ's Avatar
24 Sep 2019 06:16
#811259
As 650Ed's link suggests, NAPA carries them.
  • 2strokerider
24 Sep 2019 06:43 - 24 Sep 2019 06:44
#811264
Thanks,
I looked for it in the specifications in the Kawasaki Service manual for the part number and found no listing. All the wire diagram shows is the specification of 10 amps.
1/4" x 7/8" Glass, fast acting is what came out (7.5 A)
O'reilly's and Cycle gear don't carry them.
Last edit: 24 Sep 2019 06:44 by 2strokerider.
  • TexasKZ
  • TexasKZ's Avatar
24 Sep 2019 06:54
#811267
  • martin_csr
  • martin_csr's Avatar
24 Sep 2019 09:36 - 26 Sep 2019 05:19
#811279
What motorcycle is it? My 81 KZ650-CSR has a main fuse box & an acc fuse box.
I forget which, but one of the fuse boxes uses 25mm fuses & the other uses 30mm. One length is AGX & the other is AGC.
The length is provided in the diagrams for one of them, but not the other.
25mm = 1" & 30mm = 1-1/4". all of the fuses are 1/4" diameter.
Last edit: 26 Sep 2019 05:19 by martin_csr.
  • 2strokerider
24 Sep 2019 09:57
#811282
1979 KZ1000E
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
25 Sep 2019 01:42
#811319
26006-003 is specified for my 82 1100A, but I've been using 10A fuses from a local electronics store without problems. That is, since I swapped out the stock voltage regulator for a SH775 a couple years ago...one of my better moves.
www.cmsnl.com/kawasaki-kz1100a2-shaft-19...006003/#.XYskuLhWqt8
1982 KZ1100-A2/1170 sleeper 😀
  • martin_csr
25 Sep 2019 06:32 - 25 Sep 2019 06:33
#811331
By 2strokerider: 1979 KZ1000E.
Do an internet search for AGX fuse or AGC fuse. Your main fuse box will use one or the other. EB or amazon.com might have what you need. Some auto parts stores sell glass fuses, but nowadays they usually come as an assortment of several sizes packaged together.
Last edit: 25 Sep 2019 06:33 by martin_csr.
