Kz200 condenser
  • ioginy
  • ioginy's Avatar Topic Author
Kz200 condenser
08 Sep 2019 17:44
#810542
Hello all!
I was wondering if anyone has some knowledge on condensers. I can't figure out if they are rated in any way. I need a new one for my kz200, and was wondering if I could use a kz400 model. No resources I have found say no, but also none that say yes, or anyone that has tried a condenser that wasn't the OEM stock.
Some reassurance that I won't fry my points if i do this would be much appreciated.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Kz200 condenser
08 Sep 2019 18:26 - 08 Sep 2019 18:27
#810549
Any condensor (ignition) of the Kawasaki product line do the same Job.
Last edit: 08 Sep 2019 18:27 by Scirocco.
The following user(s) said Thank You: loudhvx, ioginy
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kz200 condenser
08 Sep 2019 20:33
#810554
I used these when they weren't available locally.
The following user(s) said Thank You: ioginy
  • ioginy
Re: Kz200 condenser
09 Sep 2019 10:36
#810585
Thank You!
That definitely puts my mind at ease!
  • martin_csr
  • martin_csr's Avatar
Re: Kz200 condenser
10 Sep 2019 05:06
#810624
Just an FYI. There are oem condensers listed on eebbaayy. The ones for the KZ400 are generally less expensive than the KZ200. I didn't search for any others. A KZ200 condenser would give a stock-type fit, in case that's a consideration.
